Docker appears to work, however when I try to run docker compose it complains of a missing dependency:
[matt@TNAS-7702 ~]# docker-compose -version
Traceback (most recent call last):
File "/Volume1/@apps/docker/dockerd/bin/docker-compose", line 6, in <module>
from pkg_resources import load_entry_point
ImportError: No module named pkg_resources
contents of /Volume1/@apps/docker/dockerd/bin/docker-compose:
[matt@TNAS-7702 ~]# cat /Volume1/@apps/docker/dockerd/bin/docker-compose | more
#!/usr/bin/python
# EASY-INSTALL-ENTRY-SCRIPT: 'docker-compose==1.24.1','console_scripts','docker-compose'
__requires__ = 'docker-compose==1.24.1'
import re
import sys
if __name__ == '__main__':
sys.argv[0] = re.sub(r'(-script\.pyw?|\.exe)?$', '', sys.argv[0])
sys.exit(
load_entry_point('docker-compose==1.24.1', 'console_scripts', 'docker-compose')()
Has anyone else seen this or know of a fix?
Kind Regards,
Matt.
