TOS 5.0.171 (x.86) is Released for Update
Release Notes
Applicable models: F2-220, F2-221, F2-420, F2-421, F2-422, F4-220, F4-221, F4-420, F4-421, F4-422, F5-220, F5-221, F5-225, F5-420, F5-421, F5-422, F8-421, F8-422, F2-423, f4-423, T6-423, T9-423, T12-423;
1. Fixed some issues of virtual disk.
2. Fixed some issues of file manager.
3. Fixed some issues of Hyper cache.
4. Fixed some issues of the storage pool.
5. Fixed some issues of the system log.
6. Fixed some issues of the network.
7. Fixed some issues of media index.
8. Fixed some issues of volume.
9. Fixed some issues of services.
10. Fixed some issues of user.
11. Fixed some issues of NFS.
12. Fixed some issues of backup.
13. Optimized some settings of Hyper cache.
Important Notes
1. This update is only for TOS 5.0.120 or later versions. If your TOS version does not meet the requirements, please upgrade to TOS 5 by reinstalling TOS.
3. If you have installed the VirtualBox application, you need to uninstall it and then update the system.
How to update your TOS?
Manual update:
1. Download the update package: TOS 5.0.171 (md5:a243f13cb7816d8aad422c23e7525d2d)
2. Go to TOS > Control Panel > General Settings > system;
3. Under the "Manual update", upload the update package;
4. Click "Apply";
5. After the system update is complete, you need to refresh your web browser;
6. Your TNAS's IP address may change after the system update, if you are not able to connect to your TNAS with the previous IP, you need to search the new IP again with the TNAC PC client;
Important Note:
After updating to TOS 5.0.171, you need to update your current TNAS PC to 5.0.33 or a later version, or you may not able to search your TNAS device.
1. TNAS PC 5.0.33 for Windows OS
2. TNAS PC 5.0.33 for macOS
It is recommended that you uninstall the previous version before installing this version of TNAS PC.
Issue report
If you encounter issues during use, please report to the corresponding TerraMaster official forum, or email your issue description and screenshots to pm(at)terra-master.com
Authenticate
Re: TOS 5.0.171 (x.86) is Released for Update
Post by Authenticate »
Still not able to edit permissions to user group for usbshares....
quella
Post by quella »
Still getting an error while attempting a TimeMachine (AFP or SMB) where the client comes back saying "Backup Disk Not Available" I have never had it working on v5.0 but it was working well when on v4 of TOS. Any direction or ideas on how to correct or get TM working again in Backup would be welcomed.
splaquet
Post by splaquet »
> would be welcomed.
@quella ,
Have you followed the instructions, in which it’s stated that the primary (root) Admin account cannot access TimeMachine functionality, and an additional user account needs to be created for access?
I was also having issues, until I read through their instructions.
kenfrog
Post by kenfrog »
download and installed - seems fine
plex is still pending updates and i tried to upload the TPK from plex ?
Any methods that i can use to force the update ?
I was thinking about winSCP and pushing the files to the correct locations ??
jparker98
Post by jparker98 »
Is there an ETR on the usbshare permissions? It has rendered 1/2 of my data inaccessible by my media server.
{L_BUTTON_AT}jparker98
There will be big changes to the USB permissions, it is expected to take a while, please be patient.
scavenger_ro
Post by scavenger_ro »
I have an APC Backup-ES700 that is connected via USB to the NAS, every time i come home .166, .171, the NAS is shut down.
Until anow was set to turn off until low battery, wich is 1830 seconds... I switched it now to wait for 5 minutes... I'll report tomorrow.
scavenger_ro
It seems the NAS is DEAD. I tried removing memory, Init disk, HDDsm it's in a continuos loop, sometimes it works for 5 minutes, sometimes 10m, in the end it simply suts down.
Probably a hardware failure.
{L_BUTTON_AT}scavenger_ro
In most cases, a TNAS freezes due to faulty memory or hard drive. You can check one by one. by the way, what is your model number?
