Recovery space after delete snapshots
TerraMaster Snapshot is a disaster recovery tool developed based on the BTRFS file system.
Minket
Post by Minket »
Hi!
I deleted snapshots but not recovery space, any idea?
Re: Recovery space after delete snapshots
Snapshots occupy very little storage space.
If you are using TOS 5, you can go to Control Panel-Volumes, select the volume and click "More"-"Usage Details" to check the usage details of the volume.
Minket
Post by Minket »
Hi, i use TOS 4.2.31 i have TNAS F4-210 and see not compatible with TOS 5, alternative view use disk?
You can view the size of the shared folder through the properties in the right-click through the file management, and check what shared folder occupies the space.
If you can't check it out, you can log into ssh: viewtopic.php?f=78&t=2350
Then use the command
cd /mnt/md0
Press Enter and then type
du -sh *
to see which directory is taking up space.
Return to “Snapshot”
