Access Denied after update
kefnsofl
Post by kefnsofl »
Greetings,
I have updated my TNAS F2-210 to 4.1.21-2002271849. After the software update I am unable to SFTP or SSH from a linux server to the TNAS with any account except for the root account. When I try to SSH or SFTP I am getting an "Access Denied" message. Before the software upgrade this was working fine. When I do login with root I do see that the home folders to have the correct owner. I also notice some my SSH port I had defined has changed back to the default so this is leading me to believe that maybe some other settings for SSH / Remote access could have possible changed as well.
Any assistance would be greatly appreciated.
Best Regards,
Keith
Re: Access Denied after update
Please try login your TOS, go to control panel and check if the SSH permission is set for the user.
kefnsofl
Post by kefnsofl »
Hello Roy,
Thank you for the information! I did not realize that I had to login as the actual admin to make the change.
Once I did that the change was easy to make. Thanks again for help. Loving my NAS its more diverse than I expected!
Best Regards,
Keith
kefnsofl wrote: 02 May 2020, 23:54 Hello Roy,
Best Regards,
Keith
You're welcome.
Return to “Network”
