USB Copy backup not starting when usb plugged in...
The brand-new USB Copy not only provides common backup features, in order to realize offline backup and defend against threats from external networks.
ckl
Post by ckl »
Hi.
I have setup a differential backup of a folder and also checked the "Start backup when usb device is plugged in"
I did the initial backup and it completed successfully. I then unmounted the usb drive and unplugged it.
As a test, I copied a folder with 15 files into the folder on the NAS. I was expecting that when I plug the USB drive in, it would recognize it and check the tasks and find that it is different than what's on the USB drive and start the backup automatically. However, when I plug it in, the drive is mounted but the backup doesn't start.
What did I do wrong?
Re: USB Copy backup not starting when usb plugged in...
The issue has been submitted to our list.
ckl
Post by ckl »
Hi.
Upgraded to .171 and issue still hasn't been fixed.
{L_BUTTON_AT}ckl
App issue is app issue, system issue is a system issue. Please wait for the next app update.
Return to “USB Copy”
