Unable to re-create a connection to Dropbox
john47uk
Post by john47uk »
Version 2.4.2
I had a connection to Dropbox at one time but it was deleted. Now, each time I try to re-connect to Dropbox the following screen shows
"Cloud Sync requires for following permission". After agreeing to it, "operation failed" shows.
When I first setup a connection to Dropbox a screen asked to login to Dropbox - that screen does not appear now, what should I change so this 'login' screen' becomes active again? John
Re: Unable to re-create a connection to Dropbox
Please try to clear the browser cache and check if the TNAS is connected to the internet.
john47uk
Post by john47uk »
Thanks for your suggestion. Yes, my TNAS is connected to the internet and this time when I tried to create a connection I was asked to login to Dropbox but after that, operation failed resulted.
MagicPhotoEvents
France
Post by MagicPhotoEvents »
I encounter a similar issue with Google Drive.
As you can see on the screenshot, the web address is not valid. I think it is the problem !
Regards,
Olivier
F5-221 TOS 5.1.131, 3 x 4TB RAID5
{L_BUTTON_AT}MagicPhotoEvents
Click "Agree" to continue the connection.
Your browser may stop the redirect link, you need to allow the redirection on your browser.
MagicPhotoEvents
France
Hello TMSupport and TMroy,
Thanks for your help
I have activated redirections and others site permissions but it does not solve the issue.
I have already used CloudSync previous versions and it was ok
Regards,
Olivier
Please try to re-enable the CloudSync.
If the issue persists, please contact our tech team to check remotely.
MagicPhotoEvents
France
I have uninstalled (with configuration files erasing) and installed it again but the issue still occurs.
Return to “CloudSync”
