TOS 5.0.166 (x.86) is Released for Update
Release Notes
Applicable models: F2-220, F2-221, F2-420, F2-421, F2-422, F4-220, F4-221, F4-420, F4-421, F4-422, F5-220, F5-221, F5-225, F5-420, F5-421, F5-422, F8-421, F8-422, F2-423, f4-423, T6-423, T9-423, T12-423;
1. Fixed some issues of volume.
2. Fixed some issues of user.
3. Fixed some issues of the scheduled tasks.
4. Fixed some issues of file manager.
5. Fixed some issues of TOS desktop.
6. Fixed some issues of backup.
7. Fixed some issues of LDAP.
8. Fixed some issues of SSD cache.
9. Fixed some issues of the hard drive.
10. Fixed some issues of regions & language.
11. Optimized some settings of on-line users.
12. Optimized some settings of system update.
Important Notes
1. This update is only for TOS 5.0.120 or later versions. If your TOS version does not meet the requirements, please upgrade to TOS 5 by reinstalling TOS.
3. If you have installed the VirtualBox application, you need to uninstall it and then update the system.
How to update your TOS?
Manual update:
1. Download the update package: TOS 5.0.166 (md5:11fb6e90aafc0aa7ec5d4c87204f1a95)
2. Go to TOS > Control Panel > General Settings > system;
3. Under the "Manual update", upload the update package;
4. Click "Apply";
5. After the system update is complete, you need to refresh your web browser;
6. Your TNAS's IP address may change after the system update, if you are not able to connect to your TNAS with the previous IP, you need to search the new IP again with the TNAC PC client;
Important Note:
After updating to TOS 5.0.166, you need to update your current TNAS PC to 5.0.33 or a later version, or you may not able to search your TNAS device.
1. TNAS PC 5.0.33 for Windows OS
2. TNAS PC 5.0.33 for macOS
It is recommended that you uninstall the previous version before installing this version of TNAS PC.
Issue report
If you encounter issues during use, please report to the corresponding TerraMaster official forum, or email your issue description and screenshots to pm(a)terra-master.com
MisterXY
Germany
Re: TOS 5.0.166 (x.86) is Released for Update
Post by MisterXY »
The USB icon is missing from the top toolbar.
https://prnt.sc/a_eA9NVRimgE
kenfrog
Post by kenfrog »
installed and rebooted, the system took about 20-24 mins to reboot and verify
the system is mounted and SMB shares on Volume1 shared but no WebUI & SSH as of yet
WebUI/SSH took a few more minutes to load after the shares (about 40-45 mins)
need to verify but the system seems stable.
dmesg seem fine as well
{L_BUTTON_AT}MisterXY
Refresh your web page.
Roccia7
Italy
Post by Roccia7 »
Hello, I installed this new version on my f-220. I have the problem you can see in the image. I already refreshed my browser and tried with another one. Has anyone else had the same problem?
https://i.postimg.cc/tCRGxnpD/docker.jpg
{L_BUTTON_AT}Roccia7
Can it be used normally after waiting for a while? It may be that the system resource overload causes the application to load slowly.
mrsnrub
Post by mrsnrub »
I’ve noticed in File Service -> Rsync Server that if you delete one of your Authorized Directories the notification box is in English however the buttons are in Chinese.
Not a major issue but should be fixed.
Did you clean your web browser cache after update?
{L_BUTTON_AT}mrsnrub
Thank you for your report! we will verify and fix it soon.
MisterXY
Germany
Post by MisterXY »
@TMroy
Currently I cannot change the rights of USBSHARE1 via the web interface. As soon as I change it and want to change the rights again, the old rights are there and not the new ones. The rights are also not changed in smb.conf.
With USBSHARE2 it is even the case that I can change the rights, the changes are applied via the web interface, but not via smb.conf. After a restart, the rights of USBSHARE2 are different again. Tested it with Firefox and Edge.
