I have verified that the correct ports are forwarded, I can establish a connection, I enter in user and password and I receive Forbidden. You don't have permission to access this resource. If I take away Webdav permissions for a particular folder it continually prompts for a user/pass as the user does not actually have permission. Is this a known issue that will eventually be fixed. I am currently on Version 4.2.39-2203011626 and it has never worked. Using a VPN is not a workaround for other family members. For me it would work just fine, but not for remote users. Asking them to utilize a VPN, which I prefer to use a licensed anyconnect through my Cisco Firewall would be the route I would take. But I want simplicity for other users.
Any help would be greatly appreciated.
Thank you!
WebDav Forbidden error
TMnorah
Re: WebDav Forbidden error
Hello, please check whether your port has been mapped, the user permission of the shared folder, the user group permission, and the WebDAV permission have been turned on.
