F2-210 Beeps Then Shuts Off Randomly
gacolitti
Post by gacolitti »
My TNAS beeps and then turns off. I have no idea why. If I'm fast enough, I can login to the TNAS on my computer and see that the device says it is "operating normally".
TMLyy
Re: F2-210 Beeps Then Shuts Off Randomly
Post by TMLyy »
{L_BUTTON_AT}gacolitti
You mean the device shuts down for no reason? , and then can you log in to the TOS system? If this is the case, take out the hard disk, turn on the empty machine, and see if it will automatically shut down. Maybe you can describe the problem a little more clearly.
The power button may be defective, when did you buy your device?
gacolitti
Post by gacolitti »
I bought it in April 2020 I believe.
It seems to have the same behavior even with the hard drives removed. It stays on for a few minutes, then beeps and shuts off. Sometimes it comes back on by itself. I have trouble accessing/logging into the machine even when the lights are on.
Please contact our service team for warranty service. It is a hardware failure.
Return to “Initialization”
