External USB hard drive rarely recognized/mounted
SunDogBC
Post by SunDogBC »
I have no problems using 32GB flash drives as external storage. But when I try using a 232GB hard drive that is in an external enclosure, more often than not, I get nothing. It just says "No USB storage device is connected!".
It works when I plug it in to a Windows laptop and the flash drives do work so I know it's not a hardware issue with the external drive. I had used the drive in one of the drive bays and set it up as a new TNAS drive (since formatted blank) and it worked then. It's only when plugged into a USB port on the back that it doesn't work.
I'm not totally versed on this but running "lsusb" in a terminal does partially recognize it:
Bus 002 Device 003: ID 0bda:8153
Bus 002 Device 051: ID 2109:0700 <---
Bus 002 Device 001: ID 1d6b:0003
Bus 001 Device 002: ID 13fe:4100
Bus 001 Device 001: ID 1d6b:0002
Verbose output from "lsusb -s 2:51":
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               3.00
  bDeviceClass            0
  bDeviceSubClass         0
  bDeviceProtocol         0
  bMaxPacketSize0         9
  idVendor           0x2109
  idProduct          0x0700
  bcdDevice           19.05
  iManufacturer           1 VIA Labs, Inc.
  iProduct                2 USB 3.0 SATA Bridge
  iSerial                 3 0000000000006121
  bNumConfigurations      1
  Configuration Descriptor:
    bLength                 9
    bDescriptorType         2
    wTotalLength           44
    bNumInterfaces          1
    bConfigurationValue     1
    iConfiguration          0
    bmAttributes         0xc0
      Self Powered
    MaxPower                2mA
    Interface Descriptor:
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           2
      bInterfaceClass         8
      bInterfaceSubClass      6
      bInterfaceProtocol     80
      iInterface              0
      Endpoint Descriptor:
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x81  EP 1 IN
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        wMaxPacketSize     0x0400  1x 1024 bytes
        bInterval               0
        bMaxBurst              14
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x02  EP 2 OUT
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval               0
        bMaxBurst              14
Binary Object Store Descriptor:
  bLength                 5
  bDescriptorType        15
  wTotalLength           22
  bNumDeviceCaps          2
  USB 2.0 Extension Device Capability:
    bLength                 7
    bDescriptorType        16
    bDevCapabilityType      2
    bmAttributes   0x00000002
      HIRD Link Power Management (LPM) Supported
  SuperSpeed USB Device Capability:
    bLength                10
    bDescriptorType        16
    bDevCapabilityType      3
    bmAttributes         0x00
    wSpeedsSupported   0x000c
      Device can operate at High Speed (480Mbps)
      Device can operate at SuperSpeed (5Gbps)
    bFunctionalitySupport   2
      Lowest fully-functional device speed is High Speed (480Mbps)
    bU1DevExitLat          10 micro seconds
    bU2DevExitLat        2047 micro seconds
can't get debug descriptor: Resource temporarily unavailable
Device Status:     0x000d
  Self Powered
  U1 Enabled
  U2 Enabled
And finally, results from "lsusb -t":
/:  Bus 02.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/7p, 5000M
    |__ Port 2: Dev 51, If 0, Class=, Driver=usb-storage, 5000M
    |__ Port 5: Dev 3, If 0, Class=, Driver=r8152, 5000M
/:  Bus 01.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/8p, 480M
    |__ Port 4: Dev 2, If 0, Class=, Driver=usb-storage, 480M
It just doesn't mount it (or whatever comes next after seeing the device). Why might this be?
F2-221 - TOS7.0.0403
BIOS/InitBoot version- MAPL0304V17
TNAS mobile (Android) - V3.5.044
SunDogBC
Re: External USB hard drive rarely recognized/mounted
Post by SunDogBC »
So no idea then. Ok.
