Docker manager broken on 08252022
Discussion about Docker
chourmovs
Post by chourmovs »
Hi people @ terramaster
Hope you recover slowly from ransomware lack of support :twisted:
Just to say docker app update of 08/25/2022 break the web interface for me, even after a TOS full reinstall and off course app itself uninstall/reinstall
Portainer helped me to make thing run as desired but I prefer docker manager on daily basis
Please never ever break docker, it's life
Thx
TNas F2-220
chourmovs
Re: Docker manager broken on 08252022
Post by chourmovs »
In fact it's working but menu take 7 seconds to appear.
It's a slight regression but I hope it could be fixed
thx
TNas F2-220
chourmovs
Post by chourmovs »
Can you reproduce? Am I alone ?
TNas F2-220
This issue cannot be reproduced in our lab. Did this happen in previous versions? Does this happen when you use other apps? It may be that the system resource usage is high and the application is slow to load. You can check the resource usage.
chourmovs
Post by chourmovs »
TMSupport wrote: ↑02 Sep 2022, 18:16This issue cannot be reproduced in our lab. Did this happen in previous versions? Does this happen when you use other apps? It may be that the system resource usage is high and the application is slow to load. You can check the resource usage.
This happen only since last docker-manager update. I have only forked-daap container running. My ressource are far from being heavily loaded. I still need to test in windows environment (I'm on a fresh Manjaro install, maybe java issue)
Thx anyway
TNas F2-220
chourmovs
Post by chourmovs »
it's a fact that
1- things are better on .163
2- since update from TNA's 4 to 5, I have couple of alert per day/week that my system is sluggish, 5 is more more cpu hungry I would say
TNas F2-220
Compare to CPU hungry, I would say TOS 5 is more helpful for you to perceive system status. TOS 4 just does not do such a job well. You can disable parts of the notification in TOS 5, you could be happyer.
chourmovs
Post by chourmovs »
TMroy wrote: ↑03 Sep 2022, 13:22 Compare to CPU hungry, I would say TOS 5 is more helpful for you to perceive system status. TOS 4 just does not do such a job well.
make sense thx
TNas F2-220
chourmovs
Post by chourmovs »
Here is a picture of my system load. In fact it's often sluggish today
TNas F2-220
chourmovs
[FIXED]Docker manager broken on 08252022
Post by chourmovs »
Fixed in the latest released 1.1.58
Thx :!:
TNas F2-220
Return to “Docker”
