TOS 5.0.158 (x.86) is Released for Update
Release Notes
Applicable models: F2-220, F2-221, F2-420, F2-421, F2-422, F4-220, F4-221, F4-420, F4-421, F4-422, F5-220, F5-221, F5-225, F5-420, F5-421, F5-422, F8-421, F8-422, F2-423, f4-423, T6-423, T9-423, T12-423;
1. Fixed some issues of the storage pool.
2. Fixed some issues of network services.
3. Fixed some issues of volume.
4. Fixed some issues of TOS desktop.
5. Fixed some issues of the app center.
6. Fixed some issues of file manager.
Important Notes
1. This update is only for TOS 5.0.120 or later versions. If your TOS version does not meet the requirements, please upgrade to TOS 5 by reinstalling TOS.
3. If you have installed the VirtualBox application, you need to uninstall it and then update the system.
How to update your TOS?
Manual update:
1. Download the update package: TOS 5.0.158 (md5:d2b30f48251761d9af3bf213d60ea823)
2. Go to TOS > Control Panel > General Settings > system;
3. Under the "Manual update", upload the update package;
4. Click "Apply";
5. After the system update is complete, you need to refresh your web browser;
6. Your TNAS's IP address may change after the system update, if you are not able to connect to your TNAS with the previous IP, you need to search the new IP again with the TNAC PC client;
Important Note:
After updating to TOS 5.0.158, you need to update your current TNAS PC to 5.0.33 or a later version, or you may not able to search your TNAS device.
1. TNAS PC 5.0.33 for Windows OS
2. TNAS PC 5.0.33 for macOS
It is recommended that you uninstall the previous version before installing this version of TNAS PC.
Issue report
If you encounter issues during use, please report to the corresponding TerraMaster official forum, or email your issue description and screenshots to pm(a)terra-master.com
Hobba
Re: TOS 5.0.158 (x.86) is Released for Update
Post by Hobba »
still a problem with smart data,
when you list it it list all drives in the same list but the selection box at the top doesn't isolate the corresponding information
nolan39
Post by nolan39 »
I have noticed that when I transfer a file over the network or remotely via the tnas link, the file always stops at 95% and never finishes. I'm not sure if this is an ongoing issue or not.
{L_BUTTON_AT}nolan39
We will verify the problem you reported. What are the properties of the files you transferred?
nolan39
Post by nolan39 »
TMzethar wrote:
I was trying to copy a Windows 98 .iso file for VirtualBox.
If you try a different file or format, does it happy the same?
nolan39
Post by nolan39 »
TMroy wrote:
> I will test it now and try to upload a different type of file.
nolan39
Post by nolan39 »
TMroy wrote:
> I just uploaded a .png file remotely and it worked and I was able to view the file. Is there any other file extensions that you would like for me to try?
We need to verify it on our lab, please wait for our information. what is the size of your iso file?
nolan39
Post by nolan39 »
The file size is exactly 640,226 KB
