FreshRSS - cURL error 60: SSL certificate problem
arqweryon
Post by arqweryon »
I have a F5-422 TNAS with TOS 5.0.156.-00203 and FreshRSS 1.3.1 installed.
I tried adding my first RSS feed to today but it returns an SSL certificate problem. This is quite a common problem for TOS and I would like to know how to fix it for FreshRSS.
The error is below:
2022-08-20 10:36:32 cURL error 60: SSL certificate problem: unable to get local issuer certificate [https://www.theguardian.com/world/rss]
Best,
Re: FreshRSS - cURL error 60: SSL certificate problem
Can you email us the details of your operation? We will verify.
arqweryon
Post by arqweryon »
Hello, I don't understand what kind of information you need, could you please be more precise?
I installed FreshRSS from the app store, tried adding an RSS feed and got the error reported in my last post.
My system's information is in the first post.
Can you tell us what feed you added? How was it added?
We don't see your case in the logs.
Can you use other links to create normally?
Return to “Others”
