TOS 5.0.157 (x.86) is Released for Update
Release Notes
Applicable models: F2-220, F2-221, F2-420, F2-421, F2-422, F4-220, F4-221, F4-420, F4-421, F4-422, F5-220, F5-221, F5-225, F5-420, F5-421, F5-422, F8-421, F8-422, F2-423, f4-423, T6-423, T9-423, T12-423;
1. Fixed some issues of the storage pool.
2. Fixed some issues of network services.
3. Fixed some issues of volume.
4. Fixed some issues of TOS desktop.
5. Fixed some issues of the app center.
6. Fixed some issues of file manager.
Important Notes
1. This update is only for TOS 5.0.120 or later versions. If your TOS version does not meet the requirements, please upgrade to TOS 5 by reinstalling TOS.
3. If you have installed the VirtualBox application, you need to uninstall it and then update the system.
How to update your TOS?
Manual update:
1. Download the update package: TOS 5.0.157 (md5:b8f7f50a063747e7bf1da7bf730df424)
2. Go to TOS > Control Panel > General Settings > system;
3. Under the "Manual update", upload the update package;
4. Click "Apply";
5. After the system update is complete, you need to refresh your web browser;
6. Your TNAS's IP address may change after the system update, if you are not able to connect to your TNAS with the previous IP, you need to search the new IP again with the TNAC PC client;
Important Note:
After updating to TOS 5.0.157, you need to update your current TNAS PC to 5.0.33 or a later version, or you may not able to search your TNAS device.
1. TNAS PC 5.0.33 for Windows OS
2. TNAS PC 5.0.33 for macOS
It is recommended that you uninstall the previous version before installing this version of TNAS PC.
Issue report
If you encounter issues during use, please report to the corresponding TerraMaster official forum, or email your issue description and screenshots to pm(a)terra-master.com
MisterXY
Germany
Re: TOS 5.0.157 (x.86) is Released for Update
Post by MisterXY »
new update old error. Usbshare2 permission error also there.
quella
Post by quella »
This release seems to have an issue with SMB as all my SMB volumes and even connecting to the server are refused. For the ones I also have AFP enabled work fine. Thoughts on the SMB potential troubleshooting? Was working fine on 5.0.156 but not on 157. I tried to disable the service and re-enable but no luck. I also did a reboot and this did not correct the issue. I did notice that then I enable or disable the SMB service in the GUI, it seems to take some time until it is completed.
Hobba
Post by Hobba »
cant seem to view hdd smart data of any drives but hdd1
kenfrog
Post by kenfrog »
I skipped the TOS 5.0.156 (x.86) and patched over with this one TOS 5.0.157 (x.86)
checking the shares and so far the system seems to be ok.
pending more testing.
I have not attempted to use USBshare, will verify the S.M.A.R.T. data on my array once the web interface is up. :)
cheers :)~
addx972
France
Post by addx972 »
since i put reset nas and all disk , i see all the volume in plex tos5 beginning be nice for me
rightLANE
Post by rightLANE »
Are you accessing the NAS through a Windows machine? Also, which TM device are you using and what version did you upgrade from? Just want to check that the drives are still accessible as network drives. I'm still on the last TOS4 but the updates are finally beginning to look acceptable and I'd like to upgrade shortly.
> (x.86)
> cheers :)~
Gandalf1369
Post by Gandalf1369 »
I can confirm that in TOS 5.0.157 I CANNOT display the S.M.A.R.T. values for any drive in the array other than HDD1. When choosing to display the S.M.A.R.T. info for any other drive only the values for HDD1 are displayed.
Does the hard disk module show all hard disks?
When you click Details, is the option to toggle HDD greyed out? Or is only one option shown? You can try restarting TNAS.
MisterXY
Germany
Post by MisterXY »
I can confirm the S.M.A.R.T bug. The values are only displayed for HDD1. I can select the other drives, but they all have the same values as HDD1
