Release Notes
Applicable models: F2-220, F2-221, F2-420, F2-421, F2-422, F4-220, F4-221, F4-420, F4-421, F4-422, F5-220, F5-221, F5-225, F5-420, F5-421, F5-422, F8-421, F8-422, F2-423, f4-423, T6-423, T9-423, T12-423;
1. Fixed some issues of network services.
2. Fixed some issues of SSD cache.
3. Fixed some issues of file manager.
4. Fixed some issues of volume.
5. Fixed some issues of app center.
6. Fixed some issues of shared folders.
7. Fixed some issues for user.
8. Optimized some settings of external storage devices.
9. Optimized some settings of backup.
10. Optimized some settings of media index.
11. Optimized some settings of hardware & power.
Important Notes
1. This update is only for TOS 5.0.120 or later versions. If your TOS version does not meet the requirements, please upgrade to TOS 5 by reinstalling TOS.
3. If you have installed the VirtualBox application, you need to uninstall it and then update the system.
How to update your TOS?
Manual update:
1. Download the update package: TOS 5.0.155 (md5:21f24b035e96fdc0a5895685955f3e44)
2. Go to TOS > Control Panel > General Settings > system;
3. Under the "Manual update", upload the update package;
4. Click "Apply";
5. After the system update is complete, you need to refresh your web browser;
6. Your TNAS's IP address may change after the system update, if you are not able to connect to your TNAS with the previous IP, you need to search the new IP again with the TNAC PC client;
Important Note:
After updating to TOS 5.0.155, you need to update your current TNAS PC to 5.0.33 or a later version, or you may not able to search your TNAS device.
1. TNAS PC 5.0.33 for Windows OS
2. TNAS PC 5.0.33 for macOS
It is recommended that you uninstall the previous version before installing this version of TNAS PC.
Issue report
If you encounter issues during use, please report to the corresponding TerraMaster official forum, or email your issue description and screenshots to pm(a)terra-master.com
TOS 5.0.155 (x.86) is Released for Update
Re: TOS 5.0.155 (x.86) is Released for Update
Hey, just installed this from 4.2.39
i seem to be having issues setting access permissions
strange when i disable the guest account i can still access shares, but if i set the guest account to deny it blocks it to the admin account.
am i missing something?
- Jac de Lad
@Hobba: The Important Notes tell us in the first sentence, that it is suitable for mahciebs running 5.0.120 and above, so...?!
[quote="Jac de Lad" post_id=20637 time=1660583114 user_id=2081]
[/quote]
i followed the instructions to update from 4.2.32...
[/quote]
and apart from permissions not working, if you have more than 10 folders it bugs out and doesn't list the remainder on the next page
Check out this post I created : * FIXED * SMB File Attributes being removed after upgrade from TOS 4.x to 5.0
viewtopic.php?f=24&t=3411
I had the same thing and ended up getting back that this is intended config and to use SMB options, but the fix I suggested works fine.
you have to add the SMB config options back in and restart the service at the ssh console : )
Cheers
Cheers
Download and update worked as expected - pending more testing but the update seems to be running smoothly on my F5-422.
Verified that the SMB permissions adding - Advanced settings and entering in :
store dos attributes = yes
map archive = yes
map hidden = yes
map readonly = yes
map system = yes
disable and reenable also works in place of putty to change the condfig.
Scheduled Task are running as expected. Scheduled task is not kicking me back to the login screen now : )
Thanks for the patch and fix for tasks :)
map archive = yes
map hidden = yes
map readonly = yes
map system = yes
I have a bug with usbshare2. I can't change the permission for this drive. I can change for 1 and 3 but not for 2. I have also take another drive for usbshare2 and have the same effect, the permission did not change in smb.conf and i also see this drive.
viewtopic.php?f=24&t=3466
@Kenfrog
thanks for the constructive help!
tho i'm not sure if this is the kind of permissions im having trouble with, its more user access im having trouble with.
still, im going to give this a go as i consider file attributes necessary
Thanks!
Thanks!
kenfrog wrote:
Just tried to implement your fix but the conf file already had these attributes set,
looks like terramaster staff have already implemented your fix :)
