TOS 5.0.152 (x.86) is Released for Update
Release Notes
Applicable models: F2-220, F2-221, F2-420, F2-421, F2-422, F4-220, F4-221, F4-420, F4-421, F4-422, F5-220, F5-221, F5-225, F5-420, F5-421, F5-422, F8-421, F8-422, F2-423, f4-423, T6-423, T9-423, T12-423;
1. Fixed some issues of volume.
2. Fixed some issues of storage pool.
3. Fixed some issues of network services.
4. Fixed some issues of SSD cache.
5. Fixed some issues of file manager.
6. Fixed some issues of shared folders.
7. Optimized some settings of backup.
8. Optimized some settings of media index.
Important Notes
1. This update is only for TOS 5.0.120 or later versions. If your TOS version does not meet the requirements, please upgrade to TOS 5 by reinstalling TOS.
3. If you have installed the VirtualBox application, you need to uninstall it and then update the system.
How to update your TOS?
Manual update:
1. Download the update package: TOS 5.0.152 (md5:214eb4ee85d6c4a5c1adda00f1b9058d)
2. Go to TOS > Control Panel > General Settings > system;
3. Under the "Manual update", upload the update package;
4. Click "Apply";
5. After the system update is complete, you need to refresh your web browser;
6. Your TNAS's IP address may change after the system update, if you are not able to connect to your TNAS with the previous IP, you need to search the new IP again with the TNAC PC client;
Important Note:
After updating to TOS 5.0.152, you need to update your current TNAS PC to 5.0.33 or a later version, or you may not able to search your TNAS device.
1. TNAS PC 5.0.33 for Windows OS
2. TNAS PC 5.0.33 for macOS
It is recommended that you uninstall the previous version before installing this version of TNAS PC.
Issue report
If you encounter issues during use, please report to the corresponding TerraMaster official forum, or email your issue description and screenshots to pm(a)terra-master.com
Charlie_Croker
Saudi Arabia
Re: TOS 5.0.152 (x.86) is Released for Update
Post by Charlie_Croker »
Installed on a working 5.0.150 version and the only issues I have seen is increased RAM, (used to hover around 15-30% currently at 52% (NAS has std 4GB), CPU is stable at 27%.
System does feel a bit quicker in usage, so not sure if there's increased RAM cache?
Overall it seems to be another good upgrade in the evolution of TOS 5.
MisterXY
Germany
Post by MisterXY »
@TMRoy, also a small language bug.
in control panal -> File Service -> SMB -> Transfer Encryption Mode.
In German you have the options "Automatisch", "Kraft" und "Deaktivieren".
Please change "Kraft" to "Erzwungen"
https://prnt.sc/XMHv1mDwocyw
Thank you for your report.
swest11
Post by swest11 »
Everything is feeling really snappy and I have no issues. Nice work, TOS5 has come a long way. Now I'd say it's better than TOS4 for me at least
quella
Post by quella »
The upgrade went smoothly. However, I seem to be having an issue with my older setup of Timemachine from 1.30. I tried a few settings changes as well as disabling the backup (Time Machine) setting and re-enabling it. The computer sees it and it shows the space free, but says that it is unable to mount the drive. I also tried to disconnect it from the client's Time Machine setting and connect it again but I get the same issue. I have also tried both AFP and SMB. Just curious if there are some other things I may have missed in my troubleshooting? Any assistance or direction would be welcomed.
parasupaman
Post by parasupaman »
Updated from 5.0.150 to 5.0.152.
Only issue I have discovered so far is that my Docker Images and Containers have all disappeared in both Docker Manager and Portainer.
Any idea how to get them back?
{L_BUTTON_AT}parasupaman
It may be that the docker application is disabled. Try enabling docker via SSH terminal. 1. Log in to the SSH. 2. Execute the command.
/etc/init.d/docker start
kenfrog
Post by kenfrog »
update seems to be fine - anyone else been having issues where "Scheduled Task" will get an error and trigger a logout ?
I have been unable to use this option on TOS 5.0 the whole time :??
MisterXY
Germany
Post by MisterXY »
@Kenfrog, i also have this error since beta.
