Lost file manager function
Drumrjoe
Post by Drumrjoe »
Newer TerraMaster user here.
I have the TerraMaster F4-210. I was able to login via Windows File manager and copy/back up folders in the past but cannot login anymore.
I can access the TOS filemanger and can also login via my IPad and see files when on the same network...
Before I try and do a factory restore on the PC, I am looking for some direction.
I have tried making sure that SMB is active in the TOS File Manager, I have even unchecked, apply and then it automatically restores the check.
Trying to copy files via the TOS File manager is not reliable and I understand that is not the preferred method any way.
Thanks in advance for any help.
Drumrjoe
Re: Lost file manager function
Please refer to the article for troubleshooting.
Drumrjoe
Post by Drumrjoe »
Thanks for your help. I am running Windows 10 and I am usually able to connect and map the TNAS but it doesn't stay connected. It seems to disconnect at random times.. I can only reconnect it by powering down and restarting the NAS. After it randomly disconnects I get the error code "0x80070035" if I try to access the NAS.
If you need screen caps of anything, please let me know.
Thanks,
Joe
Return to “Network”
