TOS 5.0.150 (x.86) is Released for Update
Release Notes
Applicable models: F2-220, F2-221, F2-420, F2-421, F2-422, F4-220, F4-221, F4-420, F4-421, F4-422, F5-220, F5-221, F5-225, F5-420, F5-421, F5-422, F8-421, F8-422, F2-423, f4-423, T6-423, T9-423, T12-423;
1. Fixed some issues of app center
2. Fixed some issues of network
3. Fixed some issues of media index
4. Fixed some issues of file manager
5. Fixed some issues of volume
6. Fixed some issues of SSD cache
7. Fixed some issues of storage pool
8. Fixed some issues of hot spare
9. Fixed some issues of shared folder
10. Fixed some issues of user
11. Fixed some issues of external storage
12. Fixed some issues of backup
13. Fixed some issues of system log
14. Optimized some settings of file service
15. Optimized some settings of scheduled tasks
16. Optimized some settings of hard drive
17. Optimized some settings of remote access
Important Notes
1. This update is only for TOS 5.0.120 or later versions. If your TOS version does not meet the requirements, please upgrade to TOS 5 by reinstalling TOS.
3. If you have installed the VirtualBox application, you need to uninstall it and then update the system.
How to update your TOS?
Manual update:
1. Download the update package: TOS 5.0.150 (md5:edd50f742de8a7452782ce76b7334f6d)
2. Go to TOS > Control Panel > General Settings > system;
3. Under the "Manual update", upload the update package;
4. Click "Apply";
5. After the system update is complete, you need to refresh your web browser;
6. Your TNAS's IP address may change after the system update, if you are not able to connect to your TNAS with the previous IP, you need to search the new IP again with the TNAC PC client;
Important Note:
After updating to TOS 5.0.144, you need to update your current TNAS PC to 5.0.33 or a later version, or you may not able to search your TNAS device.
1. TNAS PC 5.0.33 for Windows OS
2. TNAS PC 5.0.33 for macOS
It is recommended that you uninstall the previous version before installing this version of TNAS PC.
Issue report
If you encounter issues during use, please report to the corresponding TerraMaster official forum, or email your issue description and screenshots to [email protected]
MisterXY
Germany
Re: TOS 5.0.150 (x.86) is Released for Update
Post by MisterXY »
From firmware to firmware it just keeps getting better.
titanrx8
Post by titanrx8 »
@tmzethar
When updating to .150 should we first do a config backup that we can restore our settings? It seems like there are so many updates that we might be better to just install without restoring config and just manually recreating the settings.
Charlie_Croker
Saudi Arabia
Post by Charlie_Croker »
Wow! Well guys, this finally shows the real potential of TOS5.0, its fast, well featured, looks good and Terra Photos has finally grown into an App I can see myself using, I'm still not seeing much in terms of people/ID/recognition but I can see my photos and videos, scrolling through them is responsive and selecting one and it appearing on screen is instantaneous.
I'm glad you guys didn't lose heart at the critical comments and decided to let TOS5.0 do the talking. Its worked and each version gets better. I hope google translate hasnt messed this up :)
感谢铁威马开发团队和 TMroy 以及 TM 的所有人。你已经展示了你可以生产什么,很难相信你取得了多大的进步。做得好,谢谢
kenfrog
Post by kenfrog »
Update seems to be working fine, OS file level check seems to be faster.
pending more tests : )
Thanks for your efforts to bring these fixes to us.
{L_BUTTON_AT}Charlie_Croker
Thank you!
addx972
France
Post by addx972 »
I have this corrupted volume problem on disk 2 on F2-422 I bought a new hard drive the problem comes back when I turn off or restart the nas
I hope a new update to correct the problem
Did you set the new drive as a single drive storage pool and one volume? or you added it into a RAID?
You may collect a system log and send it to our tech team.
addx972
France
Post by addx972 »
I set in a single drive not in raid it works at first but if I restart the nas it no longer works
MisterXY
Germany
Post by MisterXY »
@TMRoy, the firmware runs very fine, but i have a small Question. Why are the USB Shares allways mount in the last Volume drive?
I my case it's mount in Volume 4.
Assuming Volume 4 is in sleep mode, it would be woken up by mounting a USB drive. This is one thing that has puzzled me since TOS 5.
