SSD Compatibility List (will be continuously updated)
Hardware compatibility like hard drive, SSD, memory module, Wi-Fi adapter.
Due to the large number of SSD brands and models on the market, it is difficult for users to choose the correct model. At the same time, it is difficult for TerraMaster to collect all models for verification testing. The following are the SSD brands and models that have been officially tested and verified to work on TNAS. We hope it will help you when choosing an SSD.
In addition, we also call on everyone to provide the brands and models that you have used and proved to be compatible. We will gradually update the information provided by you to the list in order to provide references and help for other users. thank you all!
M.2 NVMe 2280 SSD (M key)
Crucial P2 M.2 2280 M key 250GB
Crucial P2 M.2 2280 M key 500GB
Crucial P2 M.2 2280 M key 1TB - CT1000P2SSD8
Exascend PE4 2TB - EXPE4M1920GB
HUAWEI Xtreme 200 - 06211190
Intel 670P 2280 NVMe SSD 1TB
Kingston NV1 500 GB
Lexar NM620 512GB
SAMSUNG 980 M.2 NVMe M key 250GB - MZ-V8V8250
SAMSUNG 980 M.2 NVMe M key 500GB
SAMSUNG 980 M.2 NVMe M key 1TB
SAMSUNG 980 PRO M.2 NVMe M key 1TB - MZ-V9P1T0BW
SAMSUNG 990 PRO M.2 NVMe M key 2TB - MZ-V9P2T0BW
SAMSUNG 990 PRO M.2 NVMe M key 4TB - MZ-V9P4T0BW
SanDisk Ultra M.2 NVMe 3D SSD 250GB
SanDisk Ultra M.2 NVMe 3D SSD 500GB
SanDisk Ultra M.2 NVMe 3D SSD 1TB
SEAGATE IronWolf M.2 2280 M key 500GB
SEAGATE IronWolf M.2 2280 M key 1TB
SEAGATE IronWolf M.2 2280 M key 2TB
SEAGATE IronWolf 525 M.2 2280 M key 2TB - ZP2000NM30002
WD Red SN700 2280 SSD (M key) 250GB - WDS250G1R0C
WD Red SN700 2280 SSD (M key) 500GB - WDS500G1R0C
WD Red SN550 2280 SSD (M key) 1TB - WDS100T1R0C
WD Red SN700 2280 SSD (M key) 2TB - WDS200T1R0C
WD Red SN550 2280 SSD (M key) 4TB - WDS400T1R0C
WD BLACK SN750 250GB
WD BLACK SN850X 8TB - WDS800T2X0E
WD Blue SN550 1TB
Wicgtyp NV900 256 GB
ZettaStone CP300Y 1TB
ZettaStone CP300Y 4TB
ZettaStone CP200 1TB
Confirmed to work by other users:
ADATA XPG GAMMIX S11 Pro M.2 SSD [AGAMMIXS11P-1TT-C] 1000 GB
Crucial P3 M.2 2280 (CT500P3SSD8) 500GB
Crucial P3 M.2 2280 1TB CT1000P3SSD8
Crucial P5 M.2 2280 2TB (CT2000P5SSD8)
Intel 670P M key 1TB
Kingston NV3 1TB M.2 2280 NVMe SSD [SNV3S/1000G]
Patriot P320 1TB
Patriot P300 NVME M.2 PCIe Gen 3 x4 256GB
Sabrent Rocket NVMe 4.0 1TB
Samsung 970 EVO Plus NVMe M.2 1TB
SAMSUNG 970 EVO Plus M.2 NVMe SSD 250GB
SAMSUNG 980 PRO 2TB
Samsung 990 PRO 4TB - MZ-V9P4T0B/AM
Silicon Power A60 256GB - SP256GBP34A60M28
Silicon Power PCIe M.2 NVMe SSD 512GB Gen3
Silicon Power US75 1TB - SP01KGBP44US7505
Wicgtyp NV900-256GB
Teamgroup MP44Q 4TB
2.5" SATA SSD
ADATA SU760 256GB
Apacer AS340X 120GB
Crucial 2.5 SSD 250GB
Exascend SE4 2TB - EXSE4A1920GB
HIKVISION C260 2.5 SSD 128GB
HIKVISION C260 2.5 SSD 256GB
HIKVISION C260 2.5 SSD 512GB
Intenso SSD High 2.5 SSD 120GB
Kingspec 2.5 SSD 120GB
Kingston A40 128GB
PNY CS900 120GB
SAMSUNG 850 EVO 250GB
SAMSUNG 850 EVO 500GB
SAMSUNG 850 EVO 1TB
SAMSUNG 850 EVO 2TB
SAMSUNG 850 PRO 256GB
SAMSUNG 850 PRO 512GB
SAMSUNG 850 PRO 1TB
SAMSUNG 860 EVO 250GB
SAMSUNG 860 EVO 500GB
SAMSUNG 860 EVO 1TB
SAMSUNG 870 EVO 250GB
SAMSUNG 870 EVO 500GB
SAMSUNG 870 QVO 4TB
SanDisk ultraIII 250GB
SanDisk ultraIII 500GB
SanDisk ultraIII 1TB
SanDisk ultraIII 2TB
Seagate IronWolf 2.5 SSD 240GB - ZA240NM10001
Seagate IronWolf 2.5 SSD 480GB - ZA480NM10001
Seagate IronWolf 2.5 SSD 960GB - ZA960NM10001
Seagate IronWolf 2.5 SSD 1.92TB - ZA1920NM10001
Seagate IronWolf 2.5 SSD 3.84TB - ZA3840NM10001
WD Red 1TB - WD10JFCX
WD Red SA500 500GB - WDS500G1R0A
WD Red SA500 1TB - WDS100T1R0A
WD Red SA500 2TB - WDS200T2R0A
WD Red SA500 4TB - WDS400T2R0A
ADATA SU760 SATA SSD 256GB
Apacer AS340 SATA 120 Gb
Crucial MX500 SATA SSD 250GB
Kingspec 120GB
Intenso 2,5" SSD HIGH 120GB
PNY CS900 SSD 120GB
SAMSUNG 870 QVO 4TB
Reported being incompatible:
Micron 5100eco 1.92t
Testing Environments:
TNAS models: 221/423 series
TOS: 5.0.x/5.1.x/6.0.x
Davidz
Re: SSD Compatibility List (will be continuously updated)
Post by Davidz »
Put Crucial MX500 SSD (250GB version) in an F4-220 running TOS 5.0.144. It is an SATA drive.
It worked fine and I was able to set up a volume on it and read/write files on it.
Davidz
Thank you!
itisme
Post by itisme »
I have been running 3 Samsung 870 QVO 4TB in TRAID for the last couple of weeks and they appear to be working fine having half filled them with data.
antislow
Post by antislow »
I can confirm the 500g variant of the Crucial P2 works.
{L_BUTTON_AT}antislow
Thank you!
{L_BUTTON_AT}itisme
Thank you!
myrix
Post by myrix »
i tested:
✔️ PNY CS900 SSD 120GB
✔️ Intenso 2,5" SSD HIGH 120GB
✔️ Kingspec 120GB (works on PS3 too:o) )
{L_BUTTON_AT}myrix
Thank you!
DodgeDeBoulet
Post by DodgeDeBoulet »
The Intel 660p 512GB SSD works fine as a boot drive for TrueNAS on an F4-423.
I have not tested it with TOS.
Return to “Compatibility”
