Cloudsync doesn't sync?
joek1973
Post by joek1973 »
Am I missing something?
I have just bought my F2-423, and managed to install Cloudsync (after the download stalled many, many times).
Anyway - I have set up the connection to both my OneDrive and Google Drive. These both report as successful connections. I have setup two tasks, one for the Google Drive and one for the OneDrive.
Yet neither task has transferred any files to the cloud drive folders I have setup and set in the setup wizards for the tasks.
Am I missing something? Do I need to do something else to make it work?
Re: Cloudsync doesn't sync?
What version of TOS running on your TNAS?
joek1973
Post by joek1973 »
TMroy wrote: 30 Jul 2022, 19:07 What version of TOS running on your TNAS?
Hi - it did eventually start working, thanks. Version 5.0.144
MagicPhotoEvents
France
Post by MagicPhotoEvents »
I have the same problem.
TOS 5.0.144 updated to 5.0.150 -> issue still exists
Olivier
F5-221 TOS 5.1.131, 3 x 4TB RAID5
TMLyy
Post by TMLyy »
{L_BUTTON_AT}MagicPhotoEvents
cloudsync needs to be updated to the latest version.
MagicPhotoEvents
France
TMLyy wrote: 04 Aug 2022, 22:04 cloudsync needs to be updated to the latest version.
My CloudSync version is 2.3.2 (published 3 days ago)
TWlhq
Post by TWlhq »
MagicPhotoEvents wrote: 05 Aug 2022, 00:44
Since it takes some time for the task to start running, it may be that the task has not started running. Check whether there is a task map in the overview, and try to deactivate the enabled task or re create the task. The application will be improved in the future.
MagicPhotoEvents
France
TWlhq wrote: 06 Aug 2022, 01:31
Hello, I understand, and I have deactivated the task to create a new with bidirectionnal synchronisation mode, but it still does not run. The result of the task is "Sync Succeeded", but the Google Drive is still empty and the CloudSync log too. Regards, Olivier
thierrys73
France
Post by thierrys73 »
Hello
this the same things for me !!
thanks for helps
Tnas T6-423
Tnas F2-221
thierrys73
France
hello
it's ok for me in 4.2.4
Tnas T6-423
Tnas F2-221
Return to “CloudSync”
