Pb with create ssd cache on T6-423
thierrys73
France
Post by thierrys73 »
Hello
i have a T6-423 v5.0.125 the last version
I have 5 disk 4TB in Traid mode
I have 2 ssd m2 nvme Crucial 250gb ct250p2ssd8
BUT when i try to activate the ssd cache like raid 1 trough 250gb of cache
I have this screen and after three hours it s Always the same
I must do a default setting and re install
Cordialement,
Tnas T6-423
Tnas F2-221
Re: Pb with create ssd cache on T6-423
Hi. You are still on the honorable whitelist of the technical support mailbox, we have understood your situation well, we recommend that you try the operation we propose, update to the latest version and try again, and let us know the situation. If necessary, we can ask the engineer for You check remotely.
