I cant add 2 other disk 4TB a the pool storage T6-423
thierrys73
France
Post by thierrys73 »
Hello
i have a T6-423 v5.0.125
I have 3 disk 4TB in Traid mode and all is ok
I cant add 2 other disk 4TB a the pool Storage
i foolow this process:
Operation method:
Keep the TNAS powered on, insert a new hard drive, go to Control Panel > Storage Management > Storage Pool > Edit, and select “Expand”. Make sure that the newly added hard drive meets the requirements and you have enough spare disks slots.
when i try to add 1 disk to pool storage there is nothing to add !!!!!!!!!!!!
Thanks for help
see the photos below
download/file.php?mode=view&id=1974
download/file.php?mode=view&id=1973
download/file.php?mode=view&id=1975
Tnas T6-423
Tnas F2-221
Re: I cant add 2 other disk 4TB a the pool storage T6-423
You should try "Add more drives to the RAID". please try again.
thierrys73
France
Hi
There is nothing to add hdd4 and hh5 cant be add
I cant see it for adding
Tanks for answer
Tnas T6-423
Tnas F2-221
You can try to update the TOS version first.
