Subject says it all. Only message received is "Operation Failed".
Device is an F5-221, running TOS 5.0.135-00173.
Any information would be appreciated!
Ned
Unable to install Surveillance Manager
Re: Unable to install Surveillance Manager
Can other applications be installed normally?
Please go to App Center - Settings to see if the app's storage location has enough space.
Please check if your device is connected to the internet.
- nedhedrick
Thanks for the quick response! No other apps would install. Upon further checking, I found my volume was corrupt. So I will be fixing that and try again. I will feedback when I am done.
- nedhedrick
Update: When I resolved the issue with my Volume corruption, the installation works! Thanks for the guidance. You may close the issue as resolved.
Ned
Ned
