Raid Sync query
gcok
Raid Sync query
Post by gcok »
System F4-210
[RAID1]
TOS: Latest
A few days ago I suddenly lost SMB access and the device threw an alarm and alert about raid exception, now It takes almost 3 minutes to log in to TNAS and it has said RAID ynchronisation for the last 4 days, surely that's not right is it??
TMAY
Re: Raid Sync query
Post by TMAY »
Hello, it seems that your array is abnormal, please go to the control panel to check whether the SMB service is enabled? Can you provide us with screenshots of storage pools and volumes?
gcok
Re: Raid Sync query
Post by gcok »
SMB is enabled
but the workgroup stays blank
Storage pool Image
volume Image
Re: Raid Sync query
1. You need to fill in the information in the workgroup text box
2. Please wait for the array synchronization to complete. If the array fails again, you need to check your hard drive health.
gcok
Re: Raid Sync query
Post by gcok »
yes I already populated the workgroup field but it just stayed blank, I suspect there is a hard drive issue as its been stuck on 1% synchronizing, so will check that later
gcok
Re: Raid Sync query
Post by gcok »
I have been away for a while. The NAS is working as expected after changing from BTRFS to EXT4 however the issue with the blank workgroup persits. is there a solution to this?
Re: Raid Sync query
{L_BUTTON_AT}gcok
Please try to clean the browser cache. Collect a log, download it and send it to us to check whether there are obvious problems.
gcok
Re: Raid Sync query
Post by gcok »
the samba service starts
nothing in smb log
the workgroup remains blank
This is the output for global on testparm
# Global parameters
[global]
server string = TNAS-8A64
full_audit:failure = connect
full_audit:success = connect rmdir create_file sendfile pread_send rename unlink symlink link
full_audit:prefix = %u|%I
full_audit:syslog = true
idmap config * : backend = tdb
include = /etc/samba/smb-extend.conf
I assume workgroup should be here ?
anything else I can test?
Re: Raid Sync query
Please go to TOS desktop - Technical support - Report issues to generate a report and send it to us.
