DLNA Multimedia Server App
Dave
Post by Dave »
The DLNA server froze whilst watching a film.
Drives and data can still be read.
3 devices all display 'Server not found'.
F4-210.
Overview shows DLNA Media server 'enabled'.
Multmedia directory shows the volume #1, #2.
Tried fresh install of TNAS, same result.
Tried install of lastet software, couldn't get past 'TNAS Device' screen. very slow searching.
Deleted / wiped / reinstalled V3.2.0.6, Back to where I was 3 hours ago.
TMAY
Re: DLNA Multimedia Server App
Post by TMAY »
Hello, you can try to reduce the time of ssdp and see if it can be solved.
Dave
Post by Dave »
Yep. already tried that, still the same. What would be considered the min, max settings?
I powered up an old netgear unit, was discovered straight away.
{L_BUTTON_AT}Dave
It is recommended that you check whether the UPnP service is enabled.
In addition, it is recommended that you generate a log in Technical Support-Report issues and send it to the technical support team's mailbox for preliminary inspection.
