Error editing container
Discussion about Docker
macmpi
Post by macmpi »
I did setup a container: it works ok (though it does not start when TOS boots), but Container/Edit tabs shows the following error:
and I can not manage to edit/save any property change.
Re: Error editing container
Could you advise which image did you install? We will check and try to replicate it here.
macmpi
Post by macmpi »
macmpi
Post by macmpi »
TMSupport wrote: ↑15 Apr 2020, 14:47We will check and try to replicate it here.
Hi, would you have any update on this by chance?
The other issue is that container will not automatically start when TNAS boots (like for NFS service failing not starting at NAS reboot).
Is it ok to let our engineer have a remotely check? It's not happened here. Please confirm with support(a)terra-master.com
macmpi
Post by macmpi »
To deal with other NFS issue, I did take the red-pill and re-installed my NAS from scratch with 4.1.24.
I uninstalled Docker too, in order to restart clean, but appdata folder still has a docker subfolder, which can NOT be removed.
I even tried under SSH (as admin or root):
admin@myNAS:/mnt/appdata$ rm -rf docker
rm: can't remove 'docker/btrfs/subvolumes/6cca30a28e9ecc00a58476830b0a1bbeb01a20d2adeccac59d646696722dd96b': Operation not permitted
rm: can't remove 'docker/btrfs/subvolumes/547e93c13863d1c1bc40576f76b019d48057b8a425b7eec721ab2348d87b4807': Operation not permitted
rm: can't remove 'docker/btrfs/subvolumes/19b90768efc476d6a0f608429f8e68f53f28d50cbff3c90318f4951fc00a83b8': Operation not permitted
rm: can't remove 'docker/btrfs/subvolumes/4920fe18eed88952695b82a55da8ca56353600dcbd87272991a0f97af7af399f': Operation not permitted
rm: can't remove 'docker/btrfs/subvolumes/4516dbb6d5668afd635a7a6018f3ec3ddcd2a5e2f1def3c39051dc163a145775': Operation not permitted
rm: can't remove 'docker/btrfs/subvolumes/02c316c21580a0115211ef2e038468edd87c726840a879758338da4ac654cdca': Operation not permitted
rm: can't remove 'docker/btrfs/subvolumes': Directory not empty
rm: can't remove 'docker/btrfs': Directory not empty
rm: can't remove 'docker': Directory not empty
How can I get rid of that?
Please login as root by ssh access your TNAS, and input the cmd btrfs subvolume del /mnt/md0/appdata/*/subvolumename to delete the subfolder.
macmpi
Post by macmpi »
ok, so had to do the following for complete cleanup:
btrfs subvolume del /mnt/md0/appdata/docker/btrfs/subvolumes/*
rm -rf /mnt/md0/appdata/docker
Would be nice if Docker app uninstall does this cleanup by itself on btrfs.
Thanks!
macmpi
Post by macmpi »
Back to original issue: error editing container, after full update and cleanup of previous docker: error is still there:
Hi macmpi,
We have found the cause of this failure, we will fix it in next update. Thank you again!
Return to “Docker”
