copy large files on encrypted shared folder fail
prohdr
Austria
Post by prohdr »
copy of large files on encrypted shared folder is failing.
On normal shared folder is working.
Mapped folder in win11
With other NAS hardware it's working.
Latest TOS 5.0
prohdr
Austria
Re: copy large files on encrypted shared folder fail
Post by prohdr »
1. create encrypted share folder
2. copy >2Gb large files or 20GB file
3. expected results: copy ok
4. actual results: copy fail, tos is writing data on encrypted folder, maybe it's allocating file before copy operation, no network transfer.
Use file explorer.
The issue exists when transferring large files to encrypted shared folders via smb .
You can try to upload in TOS Desktop - File Manager.
prohdr
Austria
Post by prohdr »
any fix for smb issue with encrypted shared folders ?
with sftp it's working.
TMLyy
Post by TMLyy »
{L_BUTTON_AT}prohdr
We will discuss with the technical team and find a solution
prohdr
Austria
Post by prohdr »
Anyway, i use muCommander as alternative solution to mount sftp folder and copy files.
prohdr
Austria
Post by prohdr »
After tested :
- windows explorer - not working with large files
- total commander - working only with : use default method only : This can be set on configuration -- > operation -- > copy/delete
- muCommander - working with samba, no problems
- sftp/ftp /nfs/ linux - working
- macos - working
So problem is with windows , win11.
crisisacting
Post by crisisacting »
prohdr wrote: 18 Jul 2022, 02:48 So problem is with windows , win11.
Are you using Windows 11 Home or Pro?
On Pro, you can manually enable NFS.
Return to “File Services”
