Generally TOS 5.0.xxx does not work
markb
Australia
Post by markb »
Originally loaded TOS 5.0.???
And updated to TOS 5.0.130
Ensured the apps were the latest version.
Generally the apps do not work. I’ve been told to wait for the next update of CloudSync, update it either 2 or 3 times and does not work I am unable to do any backups from the Terra Master.
I’ve worked around this by putting software on system outside the Terra Master and do backups to it. Very messy.
Overall TOS 5.0.xxx does not work. It is fundamentally flawed.
I am unable to get
Emby or plex to work and the TOS 5.0.xxx Media server does not work either.
Please, is it possible to go back to TOS 4?? because at least that worked with the individual apps for Dropbox, OneDrive etc.
Thank you, Markb
mowy
Re: Generally TOS 5.0.xxx does not work
Post by mowy »
is in its infancy, this system needs a major update. Normal users can't create folders, if you make them administrators they can see all users' home folders so there is no privacy. It runs smoothly but it doesn't work very well.
