Remote Access application in TOS 4.1 gives "operation failed"
kilbey1
Post by kilbey1 »
I purchased a hostname from dyndns.com. I click "Enable DDNS," choose www.dyndns.com as my DNS server, and have input the username and password into the "Remote Access" application. For dynamic domain, I have tried multiple variations of combinations for "Dynamic Domain" but always get error "Operation failed!"
Note: I am able to externally connect to my hostname from outside my network, and it directs to the TOS login page on my NAS.
1. Is there a correct format for Dynamic Domain here?
2. Is this application working properly?
Running TOS 4.1 on F2-220.
Re: Remote Access application in TOS 4.1 gives "operation failed"
Would you tell the complete TOS version?
kilbey1
Post by kilbey1 »
4.1.18-2001031451
Could you please post the domain name here? I will check with our tech dept.
kilbey1
Post by kilbey1 »
grubgirl.is-a-geek.net
Is it ok to let our engineer have a remotely check for you? You can contact us at support(a)terra-master.com to confirm the details.
stacecom
Post by stacecom »
I have the same problem. The version of inadyn you have installed does not recognize any of the options in the config file:
/etc/inadyn.conf:
## inadyn configuration file
update_period_sec 600 # Check for a new IP every 600 seconds
# DynDNS username and password here
username <REDACTED>
password <REDACTED>
dyndns_system [email protected]
## Dynamic DNS hosts
alias <redacted>.dyndns.org
root@TNAS-013AB7:~# inadyn -n
inadyn[9617]: In-a-dyn version 2.3.1 -- Dynamic DNS update client.
inadyn[9617]: /etc/inadyn.conf:16: no such option 'update_period_sec'
inadyn[9617]: Parse error in /etc/inadyn.conf
inadyn[9617]: Error code 74: Missing .conf file
The only way I can get the program to run is to comment out *every* line in the config file. What's the deal with that binary?
Inadyn will be updated in next release. But even for current version, it does work well with dyndns.com dynamic domain.
kilbey1
Post by kilbey1 »
It doesn't seem to be working properly yet. I captured a small video showing current operation, but too large to attach -- when entering info and choosing Apply, screen briefly displays successful operation, then deselects checkbox (it never truly "sticks"). TOS 4.1.30. Worked ok for no-ip.com, then I turned it off, in early October. File is 2.4 mb.
You can share with us the link of the uploaded small video.
Return to “Network”
