Emby Does not find any Media Files
markb
Australia
Post by markb »
Terra Master TOS Version 5.0.129
Emby MediaServer Ver 4.7.50
Installed and configured okay. Can connect remotely via Chrome Browser and Android TV.
Connects okay to Media Folder, but does not load ANY media, not VIdeos and not Audio
Uninstalled and resinstalled and still no luck.
Have tried a number of options, no luck.
Could not find solution online
Help Please, I feel I am missing something obvious.
TMlinda
Re: Emby Does not find any Media Files
Post by TMlinda »
{L_BUTTON_AT}markb
You need to:
1.Check in the hub whether the app is enabled
2.LAN is not normally visible
3.The media user group has no permissions to share folders
4.The router has no port for remote access to the Map Emby server
markb
Australia
Post by markb »
Thanks for your suggestions, which I checked.
1 The App is enabled
2 Yes LAN is found by Emby
3 Confirmed the media group has full permissions
4 A access port forwarding on the Router has been added
And still can not see any media.
So I am open to any more suggestions.
{L_BUTTON_AT}markb
Hi.
In the Emby settings, what is the path you set?
markb
Australia
Post by markb »
I have tried multiple paths from the default path sent by Emby to others. All do not work.
Regards, Mark
TMLyy
Post by TMLyy »
{L_BUTTON_AT}markb
Did you upgrade from TOS4 or TOS5Beta to the official version of TOS5 by reinstalling? If not, please reinstall it according to the official announcement of TOS5.
In addition, please generate a log and send it to the technical support mailbox to check.
markb
Australia
Post by markb »
Thank you. I went from TOS4 to TOS5.
I followed the process, as outlined in the documentation. It was not a reinstall, but by the Factory Reset Method.
I backup all the files as suggested before this was done.
I have generated the log sent it off to Technical Support and got back a message that there were no issues in the log files.
I know everyone has been most helpful but I am at the stage, where I want to roll back to TOS4, at least I knew that all worked.
Kind Regards, Mark
Return to “Plex Media Server”
