How to configure application / port mapping
Cis
France
Post by Cis »
Aiming at opening only some applications to the internet, I would like to know a way to configure dedicated port for an application, so I can opengranularily applications to the internet, thanks to routing rules (NAT/PAT).
Some applications have this option to configure a given port (plex), but it is not the case for all; for instance wordpress.
Even on localhost I can only access wordpress via the same port than the TOS interfface (8181 by default), which prevents me to expose only wordpress to the internet.
Could you please help with a way to configure such mapping, else to know what port is used for which application?
Else a workaround for Wordpress would be appreciated.
Many thanks
Re: How to configure application / port mapping
As not all APPs can be configured a port independly, need to check each of them. For wordpress, you can edit a port for internet visiting.
viewtopic.php?f=23&t=336
Cis
France
Post by Cis »
TMroy wrote: ↑14 Apr 2020, 23:42 As not all APPs can be configured a port independly, need to check each of them. For wordpress, you can edit a port for internet visiting.
I have read already that thread you linked, it says you cannot edit port and even default one ofr wordpress is not usable so I dont understand your reply.
There is no way to define a dedicated port for wordpress application with TOS ?
Return to “Others”
