TOS 5.0.129 (x.86) is Released for Update
Release Notes
Applicable models: F2-220, F2-221, F2-420, F2-421, F2-422, F4-220, F4-221, F4-420, F4-421, F4-422, F5-220, F5-221, F5-225, F5-420, F5-421, F5-422, F8-421, F8-422, F2-423, f4-423, T6-423, T9-423, T12-423;
1. Fixed some issues with TFM
2. Fixed some issues of DDNS
3. Fixed some issues of TNAS.online
4. Fixed some issues in technical support
6. Fixed some issues in file management
7. Fixed some issues in network services
8. Fixed some issues in notifications
9. Fixed some issues in media indexing
10. Fixed some issues in the application center
Important Notes
1. This update is only for TOS 5.0.120 or later versions.
How to update your TOS?
Manual update:
1. Download the update package: TOS 5.0.129
2. Go to TOS > Control Panel > General Settings > system;
3. Under the "Manual update", upload the update package;
4. Click "Apply";
5. After the system update is complete, you need to refresh your web browser;
6. Your TNAS's IP address may change after the system update, if you are not able to connect to your TNAS with the previous IP, you need to search the new IP again with the TNAC PC client;
Important Note:
After updating to TOS 5.0.129, you need to update your current TNAS PC to 5.0.27 or a later version, or you may not able to search your TNAS device.
1. TNAS PC 5.0.27 for Windows OS
2. TNAS PC 5.0.27 for macOS
It is recommended that you uninstall the previous version before installing this version of TNAS PC.
Issue report
If you encounter issues during use, please report to the corresponding TerraMaster official forum, or email your issue description and screenshots to [email protected]
UncleJohnsBand
Re: TOS 5.0.129 (x.86) is Released for Update
Post by UncleJohnsBand »
So this says for 5.0.120 or later. I have not yet moved from 4.
Is there a way to upgrade directly to this version? If not, can you start a thread and maintain it that provides all the steps to get to current version?
Thanks.
jdalconchel
Post by jdalconchel »
Updated and everything fail. My browser's screen becomes white after some minutes logged and no choice to reboot or operating !
I'm now reinstalling this new release from scratch again.... A nightmare !
Next one I think will move to v4 ...
Charlie_Croker
Saudi Arabia
Post by Charlie_Croker »
I am one of the biggest critics of TOS5.0 (Read the Beta thread), but the last couple of releases have actually been OK. (Not brilliant, but not as bad as previous ones). Does your problem happen with every browser/device? It does seem to be a bit odd with different browsers, it also seems to drop the previous IP settings and permissions.
TMLyy
Post by TMLyy »
{L_BUTTON_AT}jdalconchel
It may be caused by your special environment or configuration or other unknown reasons. Please generate a log report and send it to the technical support mailbox for us to check.
White screen? nothing on the screen? not even a word? if possible, please send us a screenshot.
TMLyy
Post by TMLyy »
{L_BUTTON_AT}UncleJohnsBand
terribly sorry! We currently only provide the installation package of 5.0.125, you need to reinstall 5.0.125 first, and then update to the latest version online. viewtopic.php?f=28&t=3358
MisterXY
Germany
Post by MisterXY »
Media Index is deactivated again after a restart and thumbnails are not displayed even though it was activated.
kenfrog
Post by kenfrog »
umount from my clients and pending update from the gui and shell
finished download and installed the newest patch x.x.129 over x.x.128 using https WebGUI and rebooting
Post boot and now to the generic status screen on boot :
Checking file system..., please wait!
If an abnormality is found in the file system, the system will repair it,
which may take up to several hours.
Took about 10 to 40mins or so.
Sounded like the system rebooted again then :
Loading..., please wait!
Once the system is back and WebGui are up - login and all seems well :)
testing mount -a = works and the share folders are still active
testing putty = ssh shell works as expected
services are all working and no zombies ( I do see a lot of plex chown -/Vol/plex traffic but nothing stuck, just a S(start) and D(deamon) action in top )
[rootuserremoved@TNAS-F5-422 ~]# ps -aux | grep plex
rootuserremoved 7947 3.7 0.0 22932 2284 ? D 10:22 0:14 chown -R plex:admin /Volume1/Plex
rootuserremoved 7949 0.0 0.0 13936 2724 ? S 10:22 0:00 /bin/sh /etc/init.d/plex start
rootuserremoved 7973 3.7 0.0 22932 2284 ? D 10:22 0:14 chown -R plex:admin /Volume1/Plex
rootuserremoved 8022 3.8 0.0 6624 1912 ? D 10:22 0:15 chown -R plex:media /Volume1/Plex
pending more testing
Great Work - My TNAS-F5-422 works as expected :)
Charlie_Croker
Saudi Arabia
@TMsupport,
Well done guys TOS5 has improved with each release, thank you for your hard work. I have complained about TOS 5 in the past, but you really have made significant progress. Its very stable, great transfer speeds, you just need to release the wrapper stuff for third party apps.
