CloudSync General Failure
markb
Australia
Post by markb »
TOS Version 5.0.126
CloudSync 2.2.4
While it seems like a good idea to replace, OneDrive, Dropbox and all the others with the CloudSync App, it just doesn't work.
Where is the edit option. You have to delete and then start again.
Will not connect to Dropbox, no matter what configuration used.
Allows a connection to OneDrive, but when a backup task is added, you can only add a directory as at time.
It is just a general Failure.
Bring back the individual apps, which gives far better control. Regret upgrading to TOS 5
Is there a planned fix or will the individual apps be made available again????
Re: CloudSync General Failure
we are going to release a new version next week, which may resolve such issues.
markb
Australia
Post by markb »
Thank you, looking forward to the update.
markb
Australia
Post by markb »
Have the latest TOS 5.0.128
CloudSync Still does not work
Please wait for CloudSync update.
markb
Australia
Re: CloudSync General Failure - Still
Post by markb »
Now using
CloudSync 2.2.9
and
TOS 5.0.130
Still a stunning Failure.
Can you just stop working on trying to fix CloudSync, and just bring back the individual apps.
Regards, Mark
May I know what are the exact issues now for version 2.2.9?
markb
Australia
Post by markb »
I use the standard defaults settings and then selected Confirm (screen 1)
I get the Dropbox login screen where I enter in my user and password.
Then select Agree (screen 2)
Comes back to CloudSync (screen 3) and after a few minutes I get a pink message stating connection failed
After trying this 3 times, still getting the same message.
Madvic
Spain
Post by Madvic »
Upgraded to Cloudsync 2.2.9, the configuration is gone!!
How can I recover my old configuration without recreating all taks again?????
It is very annoying to lose Cloudsync configuration everytime there is an upgrade!
{L_BUTTON_AT}Madvic
The previous version and the current version have changed a lot, and the next version update will not overwrite the configuration.
Return to “CloudSync”
