Feature request: Move to at least Kernel 5.10
matt_30
Post by matt_30 »
I was hoping to use Wireguard via docker-compose in TNAS5 however it looks like the OS runs Kernel 4.19.
Uname info: Linux 3da16df88273 4.19.165+ #411 SMP Wed Jun 15 17:11:21 CST 2022 x86_64 x86_64 x86_64 GNU/Linux
RTNETLINK answers: Operation not supported
**** The wireguard module is not active, will attempt kernel header install and module compilation. If you believe that your kernel should have wireguard support already, make sure that it is activated via modprobe! ****
**** Attempting kernel header install ****
Err:1 http://archive.ubuntu.com/ubuntu focal InRelease
  Temporary failure resolving 'archive.ubuntu.com'
Err:2 http://archive.ubuntu.com/ubuntu focal-updates InRelease
Err:3 http://archive.ubuntu.com/ubuntu focal-security InRelease
Reading package lists...
W: Failed to fetch http://archive.ubuntu.com/ubuntu/dists/focal/InRelease  Temporary failure resolving 'archive.ubuntu.com'
W: Failed to fetch http://archive.ubuntu.com/ubuntu/dists/focal-updates/InRelease  Temporary failure resolving 'archive.ubuntu.com'
W: Failed to fetch http://archive.ubuntu.com/ubuntu/dists/focal-security/InRelease  Temporary failure resolving 'archive.ubuntu.com'
W: Some index files failed to download. They have been ignored, or old ones used instead.
**** No kernel headers found in the Ubuntu or Debian repos!! Will try the headers from host (if mapped), may or may not work ****
**** Kernel headers don't seem to be available in Ubuntu, Debian and Raspbian repos, or shared from the host; therefore can't compile the module. Sleeping now. . . ****
Is there a roadmap for moving to a newer kernel?
There are many many fixes and enhancements which are not a part of this kernel version.
Re: Feature request: Move to at least Kernel 5.10
Changing kernel is a big work. we may have plan to implement kernel 5.10 in TOS 5.1, but you need to wait for a while.
MisterXY
Germany
Post by MisterXY »
If you compile a new kernel, then with udf/cdrom function. It's need to mount Video ISO's files.
