Help after Factory Reset
zolt
Post by zolt »
Applications on my Terramaster F5-221 weren't working properly after updating them and even after uninstalling and reinstalling, so I backed up my configuration and did a factory reset :oops: .
My question is that now on initialization it asks for the system installation file, I downloaded from terramaster site but when I press "next" it says I'm going to lose the data on my 3 drives.
The drives were set up on Raid 5.
Is there any chance for me not to lose the data??
Please Help as there are some files that I can't lose there :cry:
zolt
Re: Help after Factory Reset
Post by zolt »
Thanks, I've managed to regain access to my data
Great! so you reinstall the TOS?
zolt
Post by zolt »
Yes i did, and after that just reassigned the permissions to the shared folders. :)
Managed to put google cloud sync and one drive sync working but plex media server still doesn't work don't know what else to try :?
What's the issue of Plex now? Cannot be started, configuring or operation failed? You can try to uninstall and reinstall it a few more times. What's the size of your media library ? It will take a long time to configure it if it's very big. You can contact us at support(a)terra-master.com to confirm the remote session to let our engineer help you if it's still not working.
