Mediaindex dont work
TiggerMS
Germany
Post by TiggerMS »
Hello forum,
I have the problem that only about 5000 files are found in the media index. I have reset the directories as I have my photos in a different location.
Unfortunately, the search process then does not continue. Does anyone have an idea how I can get him to search my entire files?
Hardware TNAS F2-220
4GB ram
8TB Seagate Ironwolf x2
Sorry for my english but google translate can't do it better. ;)
Re: Mediaindex dont work
What is your TOS version? please try to update to 5.0.124
TiggerMS
Germany
Post by TiggerMS »
It is the newest version. I install it on this morning.
TMRyan
Post by TMRyan »
Stuck at a certain number when indexing? If so, is it possible for us to check it out for you remotely?
TiggerMS
Germany
Post by TiggerMS »
I took a closer look. Even though I specify other folders to search, they are not searched. Only the directory /Volume1/Photo is searched. All other specified directories are ignored.
Switching on remotely shouldn't be a problem, but the time difference does play a role. My next available appointment is 07/02/22 at around 06:00 Berlin time zone.
Unfortunately I have a lot to do at the moment.
Greeatings
Markus
How do you know some other directories have been ignored?
TiggerMS
Germany
Post by TiggerMS »
Hello, the mediadex seems to have been running since installing the current TOS (5.0.125). Not only the files in the directory /public /photo are searched, but also in other paths. The problem is probably solved. Thanks for your attention and help.
Greetings from Germany
Markus
TiggerMS
Germany
Post by TiggerMS »
To the question of how I noticed that no other paths are searched, I would like to answer briefly. I uploaded a file to the path /public /photo. In the mediadex, the foundation of the files increased by 1. I deleted them again he sank -1. In all other paths e.g./public/drives/drive_p (for photos) I was able to change what I wanted. The stand in the mediadex remained with 4657 files.
{L_BUTTON_AT}TiggerMS
Thank you for your explanation!
The other directories maybe not added to the previous index list successfully. if you encounter further more issues, please report to us. Thank you!
