ARIA2 not accepting HTTPS certificates
Spewk
Post by Spewk »
Hi all,
whenever i try to download with ARIA2 from HTTPS sites, certificate is invalid for TNAS
certificate is valid from whatever desktop browser i use, and i can't disable "check-certificate" option via web gui on ARIA2
The latest URL i've tried is from webarchive, certificate issued by godaddy:
https://ia801403.us.archive.org/
for now, i'm downloading using HTTP only, but i would like to know if there is a way to disable the check-certificate option, or else update TNAS certificates in any way
thank you!
Daniele
Re: ARIA2 not accepting HTTPS certificates
We will look into the case and come back to you with our solution.
Return to “Others”
