qbittorrent - cannot acces files after update
Transmission, qBittorrent, Aria 2 download applications
tepe
Post by tepe »
Just updated TOS 5 from beta to official 5.0.123
before update, qbittorent working OK, after update program lost access to Volume1, when everything is stored. I cannot dowload new files also.
I try to reinstall program - its the same.
Error messege: cannot create save path
Re: qbittorrent - cannot acces files after update
If you updated to TOS 5.0.123 from a beta version, please reinstall TOS 5.0.123 and see if this issue occurs.
Saiyajin
Post by Saiyajin »
Hi there,
I have exactly the same problem when i want to dowload a new files. I can't change the directory where i want to put my files and i have an error when i start the download.
Sega82
Post by Sega82 »
I think you should check the access rights to the folder, there is a mess with access configuration in TOS 5...
By the way, how do you install torrent clients? Iv done upgrade to TOS 5 following the instruction with a reset to factory settings, now i do not have any of the torrent clients available in the app center
Nikibasso94
Post by Nikibasso94 »
Good Morning,
Try setting the folder permissions in groups to R / W the media group and it should go,
it worked for me
Brutaldeath
France
Post by Brutaldeath »
Hello
Sega82 wrote: ↑12 Jul 2022, 19:01 I think you should check the access rights to the folder, there is a mess with access configuration in TOS 5...
They have only Tramsmission now on store
You can install QBitTorrent by downloading it on https://tmnascommunity.eu/download/qbittorrent
This product is not supported by TerraMaster but it work perfectly
Return to “Download”
