[ HomeAssistant ] Open source home automation
About: https://www.home-assistant.io/
Category:
Applicable TOS: 4.1.27 or later versions
App download: https://tmnascommunity.eu/download/homeassistant
Required packages:
Python310 > 3.10.5.0
Installation/upgrade process may take longer, just wait to complete.
http(s)://yournasip:port/modules/HomeAssistant/www
About:
View demo https://demo.home-assistant.io/#/lovelace/0
Re: [ HomeAssistant ] [ 2022.6.5 ] Open source home automation
added initial version
i send you a private message explaining how to manually remove an app.
I don't think you issues is caused by these apps, i just installed from scratch Python310 and HomeAssistant.
They installed just fine and all my apps are still visible in the app center
duberic
Post by duberic »
I have installed home-assistant and it is working well on my NAS TerraMaster.
I want to use add-ons and I don't get it on Settings > Add-ons.
How can I get add-ons ?
crisisacting
Post by crisisacting »
duberic wrote: 07 Aug 2022, 04:59 How can I get add-ons ?
There aren't add-ons on the Core installation.
{L_BUTTON_AT}duberic
What add-ons do you need?
Will be done as separate tpk files.
Roccia7
Italy
Post by Roccia7 »
Hello outkastm, is it possible to have home assistant for tos 5 with supervisor?
Thanks for all you are doing!!
TNAS F2-220
TOS 5.0.176
duberic
Post by duberic »
Sorry for my late answer, but i was out.
Regarding add-ons, i read in HA documentation :
"Add-ons allow the user to extend the functionality around Home Assistant by installing additional applications.
This can be running an application that Home Assistant can integrate with (like an MQTT broker) or to share the configuration via Samba for easy editing from other computers. Add-ons can be configured via the Settings > Add-ons panel in Home Assistant. "
I was interesting by MQTT broker. Meantime, i found a way to active MQTT broker in HA application.
I'm using domoticz and trying to migrate to HA.
I'm thinking to use HA container instead of HA application. How can I remove HA application ? I'm afraid to get conflict if i use both HA application and HA container.
Thanks a lot for your work and your quick answer
If you want to remove HomeAssistant app you just have to uninstall it.
geamanug
Post by geamanug »
Please have HomeAssistant and Python ported to TOS5. I am getting error message on installation. Thanks.
