[ Python310 ] Programming Language
About : https://www.python.org
Python 3.10.x branch release
Applicable models: TerraMaster x.64 series
Applicable TOS: 4.1.27 or later versions
App download: https://tmnascommunity.eu/download/python310
http(s)://yournasip:port/modules/Python310/www
The package is using the bundle root certificate pulled from https://curl.se/ca/cacert.pem
The bundle root certificate will be pulled when NAS is rebooted or the Python310 is started manually.
And only if the local one is older than the remote one
Re: [ Python310 ][ 3.10.5.0 ] Programming Language
added initial version
Re: [ Python310 ] Programming Language
added TOS5 version
brunix86
Italy
Post by brunix86 »
Hi outkastm,
I have the following error when trying to install:
I'm using TNAS F2-221 with TOS 4.2.40, set in English language.
The install file I'm using is: Python310 TOS4 3.10.5.0 x86_64.tpk
Note: Python 2 works fine.
Could you gently help me?
Thanks!
My NAS Environment
  • TNAS F4-424
  • TOS 7.0.1278 (8GB System Partition)
  • 1x RAM Terramaster 8GB DDR5 4800 MHZ
  • 2x HDD Seagate IronWolf 12TB CMR [RAID1]
Rename the file (remove empty spaces)
brunix86
Italy
Post by brunix86 »
outkastm wrote: ↑30 Jan 2023, 19:23 Rename the file (remove empty spaces)
Hi outkastm,
After renaming the file (removing empty spaces), it worked fine!
Maybe it's a bug of the TOS platform.
Thanks.
My NAS Environment
  • TNAS F4-424
Yes, TOS4 doesn't accept empty spaces in file name.
TOS5 have no issues with this.
