msgcenter memory usage
bd2357
Post by bd2357 »
F4-210 4.2.30-2203011629
Memory usage has crept up to 67% with msgcenter taking over 50%. How do I clear this short of rebooting, and why is this happening?
ps aux --sort=-%mem | head
USER       PID %CPU %MEM    VSZ   RSS TTY      STAT START   TIME COMMAND
root      1714  0.1 50.2 572160 494528 ?       Ssl  May27  31:46 /usr/bin/msgcenter
root      2918  0.0  1.8 242172 17844 ?        S    May27   1:29 php-fpm: pool TOS
root      2922  0.0  1.7 242172 17056 ?        S    May27   1:41 php-fpm: pool TOS
root      2921  0.0  1.7 242176 16752 ?        S    May27   1:24 php-fpm: pool TOS
root      2919  0.0  1.6 268724 16100 ?        S    May27   1:31 php-fpm: pool TOS
root      2923  0.0  1.5 268716 15580 ?        S    May27   1:29 php-fpm: pool TOS
root      2938  0.0  1.1 1393396 11664 ?       Sl   May27  12:08 /sbin/nasips
root      6776  0.1  1.0  32576 10792 ?        S    11:12   0:07 /usr/sbin/smbd -D
root      3468  0.0  0.5 1054708 5492 ?        Sl   May27   0:45 /sbin/regcloud
sianderson
Re: msgcenter memory usage
Post by sianderson »
not sure, do you have many notifications showing on your admin portal for tnas
my F2-210 has been booted up for 60 days now and msgcenter is occupying 11% (total is 27%)
one thing to note is you are a version behind the latest version so first step is to update it to the latest version and see if it happens again
F2-424 TOS 7.0.1536
F2-423 TOS 7.0.1536
F2-210 TOS 4.2.44
D4-320
C/O
F4-424 TOS 6.0.794
bd2357
Post by bd2357 »
Thanks, Will let you know in a few days since the update did a reboot. It took 2 weeks last time to accumulate the 50% number
Return to “System Resources”
