SFTP QUESTION
avitabileproduction
SFTP QUESTION
Post by avitabileproduction »
hi guys, i did the setup of ftp and sftp
ftp works fine and i can see home directory once logged in
the sftp does not allow me to see the home directory once connected but only the shared folders
any solution?
avitabileproduction
Re: SFTP QUESTION
i tried webdav, but it says "configuration failed" every time
Re: SFTP QUESTION
"Configuration failed" may be that the port is already occupied, you can try different ports. In addition, whether the nas is running the webserver, if so, please update the application and try to enable the webdav service again.
avitabileproduction
Re: SFTP QUESTION
I'm not using web server and i tried every port
The result Is the same, configurazione failed
What about sftp not showing user directory?
Re: SFTP QUESTION
Is your product model F2-210/F4-210? This needs to be implemented in subsequent releases.
avitabileproduction
Re: SFTP QUESTION
Okay thank you, i hope you can fix webdav too
antislow
Re: SFTP QUESTION
Post by antislow »
I have a F2-423 running 5.0.144 and SFTP also does not seem to work at all for my home directory. I can see it listed when logging in with my client (transit), and sometimes I am able to open my home folder and get a directory listing. But most of the time I will get an error stating that it's not a directory in my SFTP client.
Re: SFTP QUESTION
{L_BUTTON_AT}antislow
Did you mean Transmit Mac?
We will verify the use of this tool again.
It is recommended that you also try other SFTP tools to see if the same problem occurs.
Is your switch/router bandwidth high enough to rule out network congestion?
In addition, after an error occurs, it is recommended that you immediately generate a log report in the technical support-Report issues, and then send it to our technical support mailbox, and we will do a preliminary analysis on it.
antislow
Re: SFTP QUESTION
Post by antislow »
Sorry, I meant Transmit. I also tested with Cyberduck and get similar error when trying to navigate to my home folder.
As for bandwidth, I have a 1 gig switch and both my computer and NAS are attached to same switch. I switched to WebDAV for now, and it's working perfectly with Transmit.
I will gather logs next time and submit them as you say.
mowy
Re: SFTP QUESTION
Post by mowy »
YES, tos 4.x run okay, TOS 5 SFTP FAIL! this is a BIG BUG!
WE CANT SEE MY HOME TOS 5 SFTP
Return to “File Services”
