Hello.
How can be done snapshots of the MUSIC folder?
Thanks!
Snapshot MUSIC folder
Re: Snapshot MUSIC folder
Hi, as Snapshot only work on btrfs file system, so you need to have at least one btrfs volume.
To use snapshot feature, you need to install the application Snapshot from app center, follow the instruction on the menu, then you can take snapshot for your shared folders.
