No custom wallpaper?
Tricky
Post by Tricky »
Just discovered that I cannot load custom wallpaper to 4.2.32 or 4.2.39 just puts "fakepath" into the file name and won't upload?
Re: No custom wallpaper?
It has been included in the fix list and will be fixed in subsequent releases.
Nodsert
Post by Nodsert »
TMRyan wrote: ↑29 May 2022, 20:49 It has been included in the fix list and will be fixed in subsequent releases.
We have had this problem for more than 6 months and no update on the F2-210 series. Can you tell us how to force the loading of another wallapaper from the ssh configuration?
Thanks.
shedlock2000
Post by shedlock2000 »
It's now April '23 -- a custom wallpaper would be nice and it's a year since the last comment!
zlau
Post by zlau »
Via SSH, you can overwrite one of the factory wallpapers.
They exist under
/usr/www/tos/static/images/wall_page/
You can upload the wallpaper to the nas as a jpg, then copy it from /mnt/ to the above directory to replace one of the presets.
If you replace 1.jpg, it will be be the first wallpaper in the wallpaper selection menu, and so-on.
