iSCSI Manager
iSCSI Manager
NAS is widely used as a storage device for virtualized computing. With TerraMaster iSCSI Manager, you can create multiple iSCSI targets and LUNs on your TNAS, and customize the capacity, permissions, and connections through a graphical interface to meet your storage space requirements in different virtualization environments.
Custom ISCSI Target IQN
Using iSCSI Manager, create multiple iSCSI targets on your TNAS and customize IQNs to help you easily identify. You can also choose to enable authentication or mutual authentication for the iSCSI Target to increase access security.
Customize network management policies
To improve network utilization efficiency, you can designate a dedicated network interface and channel for the iSCSI Target to separate the iSCSI Target's network from the networks of other services. To optimize the transfer efficiency of the iSCSI Target, you can also limit the maximum fragment size in bytes transmitted and received.
Multiple session connections
In order to adapt to complex virtualization application scenarios, iSCSI Manager allows users to enable multiple session connections from one or more initiators for iSCSI Target. Note: Multiple session connections provide flexible connection methods for initiators, but improper settings may put your data at risk! Make sure you use multiple session connections in a cluster-aware file system.
Balance performance and flexibility
You can create multiple LUNs and mount them to the iSCSI Target you specify. iSCSI Manager provides Thick provisioning and Thin provisioning configuration strategies for LUN storage space. Thick provisioning can provide better storage performance, in contrast, thin provisioning can provide more flexible storage space utilization.
Safer protection
Combined with the Snapshot technology, you can take snapshots of LUNs to prevent data loss caused by misoperations or accidents. Note: Snapshots are not supported for LUNs under the Thick provisioning configuration.
Initiator access control
By default, all connected initiators in iSCSI Manager have read and write permissions to LUNs. You can also customize access permissions for each initiator to meet the needs of various occasions.
Low-capacity write protection
When the storage space of the LUN is about to be exhausted, if the initiator continues to write data to the LUN, the LUN may be destroyed. For this reason, iSCSI Manager has specially designed the low-capacity write protection function. When the LUN is in low capacity, it will prevent the initiator from continuing to write data for protection.
