long story short
problem
I can no longer access TNAS (stuck on initialzation)
The device needs its drives reformatted from BTRFS to EXT4
relucatntly tried remote support but it did not happen....
I have am now trying to fix myself by accessing RAID drive on a spare pc using linux
tried
mdadm -D /dev/md125
lists RAID info
attempting to mount
I get mount:unknown filesystem type 'LVM2_manager
has anybody successfully gained access to their TNAS drives via mdadm
as I side note I do have a windows machine if its possible to and/or easier to use that if its possible at all ?
objective
I need to gain access to the files on either of the RAID drives so they can be backed up to 3rd drive and TNAS can be setup again
Need to Access RAID1 HDD via mdadm
- gibsongilbert
Re: Need to Access RAID1 HDD via mdadm
You could check out https://help.ubuntu.com/community/Insta ... rch=Titles. Most ways I've seen involve installing the OS, setting up the raid array, then migrating the OS over onto it.gcok wrote: ↑21 May 2022, 21:04long story short
problem
tried
mdadm -D /dev/md125
lists RAID info gb whatsapp
attempting to mount
objective
I have the same problem as you, I have no longer access to TNAS, but did not try remote support yet, can I get help?gcok wrote: ↑21 May 2022, 21:04long story short
problem
tried
mdadm -D /dev/md125
lists RAID info,
attempting to mount
objective
