i would like disable public folder and folder user.
i would like to be able to give permissions to a specific user, to a folder within another folder.
disable public
TMAY
Re: disable public
Hello, you can go to Control Panel - Shared Folders and set the permission of the folder you want to disable to Prohibit. If you want to disable user folders, please go to Control Panel - User - Advanced Settings and unenable the user home directory.
