F5-421 8GB RAM Module Upgrade
Hardware compatibility like hard drive, SSD, memory module, Wi-Fi adapter.
Asgaroth
Post by Asgaroth »
I have the TM F5-421 nas device, it comes with 4GB of memory, however, I believe we are able to upgrade the nas to 12GB by adding in an extra 8GB memory module.
I checked your amazon store and it appears that you only have the 4GB RAM module available there.
According to the F5-421 compatibility listing here for the RAM modules, it says to use the TerraMaster KBM800 module, am I able to obtain this module in Europe?
If I cannot obtain the KBM800 module for TerraMaster is there a preferred brand, that will suffice, sometheing like the HyperX 8GB SODIMM or the Crucial 8GB SODIMM
Any suggestions would be greatly appreciated.
Re: F5-421 8GB RAM Module Upgrade
Only TerraMaster RAM module is accepted, otherwise the device may be not rebooted after adding the new RAM.
Asgaroth
Post by Asgaroth »
Where can I order the 8GB memory module from? I had a look at your store page here, and it doesnt appear that you have the 8GB modules available there.
Also came across the PHS 8GB SODIMM which claims to be 100% compatible with TerraMaster.
Asgaroth wrote: 07 Apr 2020, 16:32 Where can I order the 8GB memory module from? I had a look at your store page here, and it doesnt appear that you have the 8GB modules available there.
It has not been officially tested and certified.
Asgaroth
Post by Asgaroth »
I can confirm that the Crucial CT102464BF160B 8GB memory module works in my F5-421.
My NAS now see's 12GB memory and is much happier, YMMV
Return to “Compatibility”
