SMB Creation keeps failing with "Operation Failed"
How do I see logs or diagnose why it is failing? I am trying to create a share under the "public" directory
SMB creation keeps failing
Re: SMB creation keeps failing
Your issue has not been described clearly, would you provide more specifics? how to reproduce the issue? and what is your TOS version?
Thanks for checking!
TOS 4.2.32
Here is the info I filled out then I get the "Operation Failed" message
TOS 4.2.32
"Shared folder" is wrong, hover over the icon on the far right and you can see the correct format.
Thanks for the reply.
I tried these formats and still got operation failed.
I am using an existing username / password combo, is that correct?
the 4.63 is the ip of the tnas, the 1.1 is from the example
The correct format: \\192.168.4.63\movies
Thanks for the reply, still failing, I am using an existing user and password
{L_BUTTON_AT}cjburkha
Please clear your browser cache. Check if the SMB version of your SMB server is too high or too low, and go to TOS-Control Panel-CIFS/SMB Service-Advanced, adjust the SMB version to the best compatibility: maximum SMB3 and minimum SMB1.
OK thanks for reply.
I tried both of those things still get failed
Are there error logs anywhere I can look and see what the issue is?
- sianderson
- Silver Member
can you access that share from another computer (i.e not the computer that is hosting that share?) as it could be something as simple as a firewall on the computer thats blocking access?
F2-424 TOS 7.0.0765
F2-423 TOS 7.0.0765
F2-210 TOS 4.2.44
D4-320
C/O
F4-424 TOS 6.0.794
F2-423 TOS 7.0.0765
F2-210 TOS 4.2.44
D4-320
C/O
F4-424 TOS 6.0.794
