[ Webmin ][ 1.991.0.0 ] Web-based interface for system administration
About : https://www.webmin.com/index.html
Category: Tools
Last version: 1.991.0.0
Applicable models: TerraMaster x.64 series
Applicable TOS: 4.1.27 or later versions
App download: https://bit.ly/3waZ5lk
Required packages:
Perl534 > 5.34.1.0
ModBase1 > 1.00.10.1
http(s)://yournasip:port/modules/Webmin/www
This is a powerfull tool, use it with caution !!!
About:
Webmin is a web-based interface for system administration for Unix. Using any modern web browser, you can setup user accounts, Apache, DNS, file sharing and much more. Webmin removes the need to manually edit Unix configuration files like /etc/passwd, and lets you manage a system from the console or remotely. See the standard modules page for a list of all the functions built into Webmin.
Re: [ Webmin ][ 1.991.0.0 ] Web-based interface for system administration
added initial version
